Cannot save custom settings for a Property
Hi Guys
I have created a custom property which allows a user to select a number of PageTypes located in a MultiSelect control, I wanted to limit the page types which get shown in this control so decided to use Custom settings, so i can select the page types i would want to show in my property.
The issue i am having is everytime i select the PageTypes via a checkbox and try to save i get the following error : Property Id must be of type System.Guid or EPiServer.Data.Identity
Just as a test I added another TextBox field as well into here to see if i edit only this would my settings save and yes they do save as long as i do not select any page types in the checkbox list.
Has anyone came across this before ?
Code below for Settings Class
    [EPiServerDataContract]
    [EPiServerDataStore(AutomaticallyRemapStore = true)]
    [PropertySettingsUI(AdminControl = typeof(PageTypeSelectorSettingsUI))]
    [Serializable]
    public class PageTypeSelectorSettings : IPropertySettings
        public PageTypeSelectorSettings()
            PageTypes = null;
            TestTemp = string.Empty;
        #region Public Properties
        [EPiServerDataMember]
        public PageTypeCollection PageTypes { get; set; }
        public string TestTemp { get; set; }
        #endregion
        #region Implementation of IPropertySettings
        public IPropertySettings GetDefaultValues()
            return new PageTypeSelectorSettings();
        public IPropertySettings Copy()
            var settings = new PageTypeSelectorSettings();
            settings.PageTypes = this.PageTypes;
            settings.TestTemp = this.TestTemp;
            return settings;
        public Guid Id { get; set; }
        #endregion
    Code below for SettingsUI
    public class PageTypeSelectorSettingsUI : PropertySettingsControlBase
        #region Constants and Fields
        private CheckBoxList pageTypeCollection;
        private TextBox tempTest;
        #endregion
        #region Overrides of PropertySettingsControlBase
        public override void LoadSettingsUI(IPropertySettings propertySettings)
            this.EnsureChildControls();
            var settings = propertySettings as PageTypeSelectorSettings;
            if (settings == null)
                return;
            if (settings.PageTypes != null)
                foreach (var pageType in settings.PageTypes)
                    ListItem myListItem = this.pageTypeCollection.Items.FindByText(pageType.Name);
                    myListItem.Selected = true;
            this.tempTest.Text = settings.TestTemp;
        public override void UpdateSettings(IPropertySettings propertySettings)
                return;
            settings.PageTypes = GetPageTypeCollection();
            settings.TestTemp = tempTest.Text;
        #endregion
        #region Methods
        protected override void CreateChildControls()
            base.CreateChildControls();
            this.pageTypeCollection = new CheckBoxList{ID = "PageTypeList"};
            this.pageTypeCollection.RepeatColumns = 3;
            this.pageTypeCollection.RepeatDirection = RepeatDirection.Vertical;
            this.pageTypeCollection.RepeatLayout = RepeatLayout.Table;
            this.pageTypeCollection.CssClass = "epi-dataTable";
            this.pageTypeCollection.DataSource = (object)PageType.List();
            this.pageTypeCollection.DataTextField = "Name";
            this.pageTypeCollection.DataValueField = "ID";
            this.pageTypeCollection.DataBind();
            var label = new Label { Text = "Page Types", AssociatedControlID = "PageTypeList" };
            this.AddNewRow(label, this.pageTypeCollection);
            this.tempTest = new TextBox { ID = "TempText" };
            var labtest = new Label { Text = "Test", AssociatedControlID = "TempText" };
            this.AddNewRow(labtest, this.tempTest);
        private PageTypeCollection GetPageTypeCollection()
            var collection = new PageTypeCollection();
            foreach (ListItem listItem in this.pageTypeCollection.Items)
                if (listItem.Selected)
                    int id = int.Parse(listItem.Value);
                    collection.Add(PageType.Load(id));
            return collection;
        #endregion
#59035
May 17, 2012 18:27
example of the issue can be seen here : http://screencast.com/t/0Tr8y2c3Vqm
#59036
May 17, 2012 19:13
My initial thoughts are PageTypeCollection cannot be saved into the DDS so will try converting this into an IntegerCollection
#59043
May 18, 2012 11:36
After a bit of faffing around and changing the PropertyType this is now working. I changed it to string value and saving the options as Comma delimiated integers.
#59078
May 18, 2012 16:59
