Edit Panel / Edit Tree Custom Plugins
Guys I have created a custom Edit Tree plugin which contains links to specific EPiServer pages when these links are clicked i want the page to open on the main Edit Panel although default to another Custon Edit Panel plugin i have created rather than the preview tab. How can i achieve this
I am using CMS 6 R2
#57268
Mar 07, 2012 13:54
Something like this should do the trick (you need to use another plug in to select your plug in):
[GuiPlugIn(Area = PlugInArea.EditPanel)]
public class SelectYourEditPanelPlugIn : ICustomPlugInLoader
    public PlugInDescriptor[] List()
        // hook LoadComplete-event on EditPanel page
        EditPanel editPanel = HttpContext.Current.Handler as EditPanel;
        if (null != editPanel)
            editPanel.LoadComplete += new EventHandler(editPanel_LoadComplete);
        //Never return a plugin - we don't want to add tabs.
        return new PlugInDescriptor[0] { };
    protected void editPanel_LoadComplete(object sender, EventArgs e)
        // find the TabStrip with id = "actionTab"
        TabStrip actionTabStrip = this.FindControl<TabStrip>(sender as Control, "actionTab");
        //Find the tab
        if (actionTabStrip != null)
            int yourPlugInID = PlugInDescriptor.Load(typeof(YourPlugIn)).ID;
            foreach (var item in actionTabStrip.Controls)
                Tab actionTab = item as Tab;
                if (actionTab != null && actionTab.PlugInID == yourPlugInID)
                    actionTabStrip.SetSelectedTab(actionTab.ID);
    // try to locate control of type T with ID==id
    // recurses into each childcontrol until first match is found
    protected T FindControl<T>(Control control, string id) where T : Control
        T controlTest = control as T;
        if (null != controlTest && (null == id || controlTest.ID.Equals(id)))
            return controlTest;
        foreach (Control c in control.Controls)
            controlTest = FindControl<T>(c, id);
            if (null != controlTest)
                return controlTest;
        return null;
    protected T FindControl<T>(Control control) where T : Control
        return FindControl<T>(control, null);
See http://labs.episerver.com/en/Blogs/Allan/Dates/2009/1/Neat-Trick-Modifying-Edit-Mode-Tabs/ for more info on where I got the inspiration from
#57271
Edited, Mar 07, 2012 14:31
Cheers mate worked like a charm.
#57272
Mar 07, 2012 17:19
had some problem when trying to move off the tab although moved the call into editPanel_PreLoad instead, so now it only default's to the tab if selected tab is empty.
#57273
Mar 07, 2012 18:19
Yeah, I forgot to add that you should check something in the querystring to see if you should select or not :)
#57274
Mar 07, 2012 18:20
