You can change the login url in web.config and point to your own login page. In your custom login page you can check the querystring.
Or even better, create a http module and authenticate the user there.
Just to clearify, you don't authenticate the user/request in your provider. Authenticate your user in the login page, http module or elsewhere.
I want to customise the login process in the AlloyTech sample
Instead of a given login & password, i want to authenticate user using a gotten ID wich exists in the url (..../login.aspx?ID=xxx)
to do that, i've implemented a custom membership provider and a role provider
i configured the sample to use my custom membership and role provider in the web.config and the sample does use thease providers, i know it because i checked it using a known login & pwd wich configured in the custom membership provider
the problem is that :
1- i can't get the ID from the url inside my custom provider
2- i don't know where to call my custom method : public bool ValidateUser(string ID) , i think that this should be done inside the login.login method (at least that's what is mentioned in the login.aspx code) but i don't know where this method exist; i could't find it !
And thanks to tell me if i am messing anything else here or any other step to do
