Set the default page to go to after login in CMS?
Hey All,
i was wondering if there is a setting to go to the edit-mode of CMS after login immediately instead of the start page (with the gadgets)...
Hope there is a quick setting for this... i thought there should have been a setting in the episerver.config sitesettings, but i couldnt find a thing..
thanks in advance
#63029
Nov 07, 2012 15:10
Could you provide more information about what you do and what you would like to happen, cms version etc.
#63032
Nov 07, 2012 16:15
Hi Per,
Using Episerver 6 R2...
Ok i have my site localhost... Now when i want to go to the CMS..
i go to localhost/cms ... I now get the login page.. I login succesfully but the page i see then is the START Dashboard, see image below..
Start dashboard is the page where you can add you gadgets(widgets) etc.
I want to immediately let it redirect to the edit mode of the CMS section where i see my pagetree..
The url to edit mode is localhost/cms/CMS/Edit/Default.aspx
So where can i change that it should not bring me to the start dashboard, but immediately to the localhost/cms/CMS/Edit/Default.aspx
https://www.dropbox.com/sh/s30llwmxgwt09d6/A_UiCalR_x/Capture.JPG
I hope this is clear now... I hope you can help!
#63036
Edited, Nov 07, 2012 16:55
if you just write locahost/cms/edit and then login you will be redirected to edit mode and the pagetree.
Or if you av a login button you could just click edit mode option in the right click context menu.
#63037
Nov 07, 2012 17:01
Ok you see... the client wants a easier way to get to the edit mode with just going to the site and then put a /cms behind it, login and voila, they see the page tree.
So without having to enter the complete edit-mode url /cms/CMS/edit/ (this is the correct url).. /cms is easier to remember then the other one.
It would also save them a couple of extra clicks after the normal login which bring them to the start dashboard.
I thought this should have been a simple setting in the episerver.config or web.config..
#63038
Nov 07, 2012 17:13
Do a redirect in the IIS or create a httpmodule that redirects the users to complete url.
Or you could change the edit mode url in the config files so it's not cms/cms/edit but just cms/edit. An extra /edit after cms isn't that hard to remember.
#63039
Nov 07, 2012 17:22
