Property Exists vs Property Not Set
I need a way to tell whether a page does not have a particular property defined versus having the property defined but no value set.  How can I do this?
pseudo code for what I want to accomplish:
if(CurrentPage contains a property called "theProperty")
    if(CurrentPage["theProperty"] != null)
        do something...
I only want to apply the logic in the second "if" statement if the page has a property called "theProperty" defined.
Thanks!
#63421
Nov 19, 2012 18:50
If a property is not set it will not be saved in the database. But I guess you could load the actual pagetype definitions to check if your property exists.
Check out the PageType class.
#63430
Nov 19, 2012 19:22
There is a function in the property class:
CurrentPage.Property.ExistsLocally("MyProp")
http://sdk.episerver.com/library/cms5/html/M_EPiServer_Core_PropertyDataCollection_ExistsLocally.htm
#63431
Nov 19, 2012 20:41
Cr*p I've totally missed that one possibility.
#63432
Nov 19, 2012 20:48
That might do it.  Testing now.
#63433
Nov 19, 2012 21:03
Done and done.
Thanks!
#63434
Nov 19, 2012 21:11
Your'e welcome :)
#63435
Nov 19, 2012 21:20
