XForm events not firing, despite initialization of event handler.
I have debugged my XForm-code and can see that this code runs:
   public void XForm_ControlSetup(object sender, EventArgs e)
            XFormControl control = (XFormControl)sender;
            control.BeforeLoadingForm += new LoadFormEventHandler(XForm_BeforeLoadingForm);
            control.ControlsCreated += new EventHandler(XForm_ControlsCreated);
            control.BeforeSubmitPostedData += new SaveFormDataEventHandler(XForm_BeforeSubmitPostedData);
            control.AfterSubmitPostedData += new SaveFormDataEventHandler(XForm_AfterSubmitPostedData);
    However, when I click the send-button, the method that is bound to the SaveFormDataEventHandler isn't executed.
Instead the page is loaded again and the XForm_ControlSetup-method, XForm_BeforeSubmitPostedData(object sender, SaveFormDataEventArgs e)-method etc, runs again.
How do I solve this?
Thanks!
#62429
Oct 24, 2012 13:34
Here is the solution:
http://warting.se/2011/05/10/xform-aftersubmitposteddata-is-not-triggered/
"If XForm_AfterSubmitPostedData is never triggered this is probably because the SMTP settings is wrong in web.config(!!?)."
#62437
Edited, Oct 24, 2012 14:57
you can also check to make sure that you are allowed to submit the form multiple times.  This is done in the xform editor.
#64044
Dec 08, 2012 5:21
