Showing a parent property if currentpage property is null
I have a parent page with a property called “result” which is XHTML string. This page has multiple sub pages with a property called “subResult”. On the subpages I want to display the parents “result”-property only if “subResult” is null. The “result” property can have dynamic content which use a web-usercontroler.
Are the any good solutions out there ?
#62488
Oct 25, 2012 18:03
On the subpages you can have an EPiServer:Property runat="server" id="subpageresult".
In the subpages codebehind you could do something like this (pseudo code)
if (GetPage(CurrentPage.ParentLink)["result"] == null)
  subpageresult.PropertyName = "subResult";.
If you want't to display the parent page result property instead you do like this.
subresult.PropertyName="Result"
subresult.PageLink = CurrentPage.ParentLink
#62489
Oct 25, 2012 18:54
