404Handler 301 Redirects and multiple sites
Is there any way to differentiate redirects created using the epicode 404 Handler on a per site basis? I have a multi-site implementation with 3 sites and each re-direct is applied to all three sites. Is there anyway to assign a redirect specific to each site. Ideally it would be good to be able to report on redirects per site too.
#62617
Oct 30, 2012 22:43
Do not think that is possible by default with that handler. but if I remeber correctly i should work on enterprise solution though. Could download code and setup project to see if you can make the changes you need!? Guess you would need to add som functionallity to select site when adding the redirects in the gadget.
#64150
Dec 11, 2012 15:21
