Making IIS 7.5 web.config work with IIS6.0
We have a CMS 6 site which needs to go live. The only issue I have right now is that the dev environment is using IIS 7.5 while the staging environment uses IIS 6.0.
Dev environment = IIS 7.5
Staging environment = IIS 6.0
Using the IIS 7.5 web.config on the staging environment without making any changes loads the site all right. But the Home page layout seems a bit off. Images are missing, a user control is not visible (though it's on the page when you view the source code). Menu and submenu all results to a "page cannot be found" error.
So I used an IIS 7.5 web.config file instead. But still results are the same.
I modified the proper VPP and site url and even have the correct episerver directory references on the config files.
I deployed the site manually and not via EPiServer Deployment Center.
Hoping someone can help me with this.
Cheers,
Jan
#53274
Sep 05, 2011 6:04
I was able to fix the broken links but still the EPiServer right click context menu doesn't show up.
#53275
Sep 05, 2011 6:35
Hi Jan ,
Hi am also facing the same issue in IIS6. Home page is displayed but on click of any link i am getting "page cannot be found".
Hw did you fixed this issue?
#58285
Apr 18, 2012 7:13
