Set your role and membership provider to windows or use the multiplex one if you wish to use both windows and SQL. Then you should be able to login using your windows credentials.
/Petter
Did you use a domain in the windows credentials?
By default episerver installs use windows credentials. Whatever you signed onto your machine with should work.
i downloaded and configured the Alloy Technologies site on my system.But how i can login into Admin mode i.e what is the username and password for that.
I tried with my windows credentials but no able to login.
anyone had idea?
Atul
