Seeing as you want to add tabs dynamically, I think the most elegant solution would be to make a custom property for the tab control - you could then store the definition of each tab in a string as xml or something clever.
The most comprehensive guide to creating custom properties is found here: http://joelabrahamsson.com/entry/how-to-create-a-custom-episerver-property
Hi Jan
Check out the Multiple Property control I have created http://episerveresmp.codeplex.com/
This would allow you to easily create a property for your custom tabs.
You could also override the CreateDefaultViewControls method within the property implementation to render the relevant markup when bound to an EPiSever:Property.
Full usage documentation can be found here
Lee
I'm in the process of creating a Tab Control but I'm just wondering how I could implement it in EPiServer. What Property types would I use and how would a user add Tabs to it dynamically.
