"Remember" value of custom property
So, I've created my first ever custom property - a dynamically filled DropDownList. Works great until I go back and edit an already saved page because it doesn't remember what my choice was. I'm sure there is some function I need to call to do this, I just don't know which one it is. Care to help me out? How do I set the selected value to the saved value from the last edit?
#49715
Mar 29, 2011 15:43
Depends on how your code looks, but something like this:
public class PropertyWeekNumberDropDownControl : PropertySelectControlBase
	protected override void SetupEditControls()
		this.SetupDropDownList();
	private void SetupDropDownList()
		this.EditControl.DataSource = GetWeekNumbers;
		if (this.WeekNumberDropDown.Value != null)
			this.EditControl.SelectedValue = this.WeekNumberDropDown.Value as string;
		this.EditControl.DataBind();
	public PropertyWeekNumberDropDown WeekNumberDropDown
		get
			return PropertyData as PropertyWeekNumberDropDown;
#49718
Mar 29, 2011 16:00
This should save your value:
 public override void ApplyEditChanges()
                if (!String.IsNullOrEmpty(yourControl.SelectedValue))
                    SetValue(yourControl.SelectedItem.Value);
 And then to set it you need to go through your options and then check if its equal the current value:
 foreach (var val in yourListOfOptions)
 ListItem li = new ListItem(val, yourListOfOptions[val]);
   li.Selected = currentPropertyValue == yourListOfOptions[val];
   yourControl.Items.Add(li);
 Something like that should do it I think
#49719
Mar 29, 2011 16:01
That did the trick. I was uncertain how it would assume the Get would belong to the page being edited but with a function name that revealing I see the connection. Thanks guys!
#49720
Mar 29, 2011 16:48
If someone might read this one still I've got another question. Is it possible to reach a dynamic property in the code for the custom property? I need to get the value of one to fill the dropdown. I usually just use CurrentPage["MyProperty"] but that won't work in this case.
#49734
Mar 30, 2011 9:42
