Extra field in LinkCollection property
I need to add an extra text field besides Text in link collection property. How can I achieve that and I don't want to use the title property. need to add an extra besides these two.
-Nitin Jain
#49146
Mar 07, 2011 10:25
There is a open source property on epicode that might fit your needs:
http://labs.episerver.com/en/Blogs/Stein-Viggo-Grenersen/Dates/112262/112263/The-king-of-properties---Multipage-property/
Or you can always make your own property and base it heavliy on the link collection property.
#49150
Mar 07, 2011 10:54
You can also use Itera.MultiProperty
https://www.coderesort.com/p/epicode/wiki/Itera.MultiProperty
Here you have some more options
#49151
Mar 07, 2011 11:09
Thanks, But the issue with itera is that when we need it for publishing articles and in different languages.
With simple linkcollection language works perfectly but with itera we then also need to define the language for every link which means 6-7 and more for each link which is not good way.
Is there any other way?
#49154
Mar 07, 2011 12:29
If you set up a Itera.MultiProperty to points to a page, you could in the output find the page name of the page and use that.
#49155
Mar 07, 2011 12:35
Thanks for all the help
#49190
Mar 09, 2011 6:38
