What you'd need to do is hook the ControlCreated event of the XFormControl, then iterate through the controls collection. When you find an IValidator control, you need to set a custom message in the ErrorMessage property.
See http://www.frederikvig.com/2010/11/semantic-markup-with-episerver-xforms/ for an example.
Thanks, IValidator is adding the custom error message.
But I am trying to display the error message from my xml.
<email>
<caption>E-mail address</caption>
<inlineerrormessage>Not a valid e-mail address.</inlineerrormessage>
<summaryerrormessage>* is not a valid e-mail address.</summaryerrormessage>
</email>
<requiredfield>
<inlineerrormessage>This field is required</inlineerrormessage>
<summaryerrormessage>You haven't specified all required fields</summaryerrormessage>
</requiredfield>
this is the xml which tag which is used to display message. I am not able to figure out how summaryerrormessage of required field and for a particular datatype is set.
I want to add to validation on Age [RequiredFieldValidation and RegularExpressionValidator] which is in XForm.
If I add <asp:ValidationSummary ID="ValidationSummary1" ValidationGroup="XForm" DisplayMode="BulletList" ShowSummary="true" EnableClientScript="true" runat="server" /> in the form in which XForm is loading it shows only one ErrorMessage for all validations.
I also tried adding custom validation in global.asax.cs
but the problem is that it also show only one custom errormessage. But if i remove this code and keep the validation summary on the aspx page then after showing the errormessage "" it does show the second numeric message.
Any idea how can i add the custom errormessage and 2 validation.
