What version of EPiServer and IIS are you installng it on? Further more, is the compressed file, nuget or source you are using?
It's CMS 6 R2, IIS 7. And I'm using the compressed file, so I'm installing through Development Center.
Does the logfile give a hint about what is causing it?
It's usually stored in C:\Program Files (x86)\EPiServer\Shared\Install\Logs
Thank you so much for your help Christian! I found on the logs that the access to the config files was being denied because they are in TFS, so I checked them out for edit and the installation finished successfully. Tusen tack!
/Kenia
Hello!
I want to install the 404Handler module for CMS6 that is available for download on coderesort https://www.coderesort.com/p/epicode/wiki/404Handler, but when i start the installation i get an error that says "A bulk installation has not been started", and then the installtion is interrupted. Any idea what it can be?
Thanks!
/Kenia
