Strange things with our intranet
Hi all!
Some strange things here. There were some hick ups with surfing to our intranet, but now it is working again.
Hower when surfing to the url from IE on the webserver I get an error message (see below) and the same for surfing to localhost. Also when login in to Epi Server the left menu with the pagetree is gone and I get a "Page can not load".
Here is the error message I get on the server. Any ideas? Thanks
Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.
Exception Details: System.Data.SqlClient.SqlException: Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.
Source Error:
Stack Trace:
[SqlException (0x80131904): Timeout expired.  The timeout period elapsed prior to completion of the operation or the server is not responding.]
System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +1950890
System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +4846875
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +194
System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2392
System.Data.SqlClient.SqlDataReader.ConsumeMetaData() +33
System.Data.SqlClient.SqlDataReader.get_MetaData() +83
System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +297
System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +954
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +32
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +141
System.Data.SqlClient.SqlCommand.ExecuteDbDataReader(CommandBehavior behavior) +12
System.Data.Common.DbCommand.ExecuteReader(CommandBehavior behavior) +10
EPiServer.Common.Data.DatabaseHandler.GetReader(Boolean inTransaction, String sp, CommandType commandType, Object[] args) +63
EPiServer.Common.Data.DatabaseHandler.GetReader(String sp, Object[] args) +31
EPiServer.Common.Security.Internal.Data.SecurityFactory.GetUserGroups(User user, SecurityHandler securityHandler) +123
System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +0
System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) +71
System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) +261
System.Delegate.DynamicInvokeImpl(Object[] args) +84
EPiServer.Common.Cache.CacheHandler.GetCachedObjectImplementation(Delegate cacheObjectGetter, Object[] getterArgs, Nullable`1 cacheTimeSpan, NotFoundInCacheAnnouncer notFoundInCacheAnnouncer, String[] key) +398
EPiServer.Common.Cache.CacheHandler.GetCachedObject(Delegate cacheObjectGetter, Object[] getterArgs, String[] key) +74
EPiServer.Common.Security.Internal.SecurityHandler.GetUserGroups(IUser user) +269
EPiServer.Common.Security.User.get_Groups() +33
EPiServer.Common.Web.Authorization.Integrator.SynchronizeUser(MembershipUser membershipUser, String password, Boolean enableCreateNew) +637
EPiServer.Common.Web.Authorization.IntegrationHttpModule.context_AuthenticateRequest(Object sender, EventArgs e) +280
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.3620; ASP.NET Version:2.0.50727.3618
#55381
Nov 30, 2011 16:00
Now I got another one:
Could not load file or assembly 'Nykoping.InternWeb.Community' or one of its dependencies. Access is denied.
Exception Details: System.IO.FileLoadException: Could not load file or assembly 'Nykoping.InternWeb.Community' or one of its dependencies. Access is denied.
Source Error:
Assembly Load Trace: The following information can be helpful to determine why the assembly 'Nykoping.InternWeb.Community' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileLoadException: Could not load file or assembly 'Nykoping.InternWeb.Community' or one of its dependencies. Access is denied.]
System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +43
System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +127
System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +142
System.Reflection.Assembly.Load(String assemblyString) +28
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +46
[ConfigurationErrorsException: Could not load file or assembly 'Nykoping.InternWeb.Community' or one of its dependencies. Access is denied.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +613
System.Web.Configuration.CompilationSection.LoadAllAssembliesFromAppDomainBinDirectory() +203
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +105
System.Web.Configuration.AssemblyInfo.get_AssemblyInternal() +29
System.Web.Compilation.CompilationUtil.GetTypeFromAssemblies(AssemblyCollection assembliesCollection, String typeName, Boolean ignoreCase) +132
System.Web.Compilation.BuildManager.GetType(String typeName, Boolean throwOnError, Boolean ignoreCase) +291
System.Web.Profile.ProfileBase.AddProfilePropertySettingsForCompilation(ProfilePropertySettingsCollection propertyCollection, Hashtable ht, String groupName) +294
System.Web.Profile.ProfileBase.GetPropertiesForCompilation() +185
System.Web.Compilation.ProfileBuildProvider.get_HasCompilableProfile() +20
System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +245
System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +128
System.Web.Compilation.BuildManager.CompileCodeDirectories() +265
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +320
[HttpException (0x80004005): Could not load file or assembly 'Nykoping.InternWeb.Community' or one of its dependencies. Access is denied.]
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +58
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +512
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +729
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +8894223
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +85
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +259
#55386
Nov 30, 2011 16:17
Problem solved. Some access rights was wrong, inhered from development.
#55387
Nov 30, 2011 16:44
