Search for loginUrl in your web.config, should be in a authentication node.
Hello and thanks for your reply! Actually i could see that this attribute was set to the login page in the project instead for the default one in Epi, no idea why, so now it makes sense. It is displayed though without styles, although the CSS are loaded...but well, this is a different issue. Thanks again!
/Kenia
Might be cached bad, try clearing caches in the browser. Also check with firebug to see if there is any unauthorized access to static files.
Hello everyone!
I have a project which I have migrated from CMS5 to CMS6 R2. Everything is working fine now, but i'm having a URL problem in the login page to the CMS interface. When i write the URL to edit mode or admin mode, i'm automatically redirected to a login page that's container in the project, instead of "~Util/login.aspx". Where should i check to change this back?
Thanks in advance,
/Kenia
