It will add a validator to the page and set that validator to not valid. Add a ValidationSummary control to pick up the error message, you have to set the ValidationGroup to the same string for both the ValidationSummary and the Property or XFormControl control you are using to display the Xform, example:
<xforms:xformcontrol ID="FormControl" runat="server" ValidationGroup="XForm" />
<asp:ValidationSummary runat="server" ValidationGroup="XForm" />
HI Magnus,
Actually i created one xform with input controls.Now i want to extract the values of those controls in XForm.How to achieve this? any idea? pls share it,,,,,,,,,
If I create a form and set that anonymous answers is not allowed, the submit button is still enabled if I browse to the page with the form and not being logged on. The only difference is that nothing happens whe I press the submit button.
I would likte to either disable the submitbutton if user is not logged on or display a message when a not logged on user presses the button.
Tried to hook onto the BeforeSubmitPostedData event but can't get it to work.
