get text of all the textbox inside episerver pagelist
Hi I have a episerver pagelist  showing the name of page and textbox field which is editable. Then I have a button in my page which is not inside the pagelist. onclick of this button i want all the values of the textbox. I am trying
private void Button_Click(object sender, System.EventArgs e)
                foreach (PageList item in productList)
                    Response.Write(((TextBox)item.Controls[1]).Text);
where productList is the id of the pageList. But dosnt work.Please help
#47099
Jan 14, 2011 7:47
There are several ways of doing this but you can try
 var boxes=new List<TextBox>();
 FindControls(productList,boxes,"id2box");
 foreach (TextBox box in boxes)
  Response.Write(box.Text);
void FindControls(System.Web.UI.Control start, List<TextBox> result,string id)
    foreach (System.Web.UI.Control item in start.Controls)
        if (item is TextBox && (item as TextBox).ID==id)
            result.Add(item as TextBox);
        FindControls(item, result,id);
#47102
Jan 14, 2011 9:30
thanks for the reply.But my pagelist is like
<EPiServer:PageList  runat="server" ID="productList" >
                        <ItemTemplate>
                           <tbody>
                            <tr>
                                <td><img src='<%# GetImageURL(((EPiServer.Core.PageData)Container.DataItem).PropertyValue<string>("ProductID")) %>' alt=""></td>
                                <td width="20"><h4><a href="<%#Eval("LinkURL") %>"><%# Container.CurrentPage.PageName %></a></h4>
                                   <%# Container.CurrentPage.Property["MarketingName"].Value %>
                                </td>
                                <td>Määrä<asp:TextBox ID="txtFirstName" runat="server" ></asp:TextBox>
                                <td><asp:LinkButton  runat="server" class="remove" Text="Poista" OnCommand="removeProduct" CommandArgument="<%# Container.CurrentPage.PageLink %>"></asp:LinkButton>
                               </td>
                           </tr>
                           </tbody>
                        </ItemTemplate>
                     </EPiServer:PageList
along with the value of text I also know it is bounded to whichPagelink "Container.CurrentPage.PageLink"?
#47103
Jan 14, 2011 10:04
You have several options here. The quick fix is to add
<asp:TextBox ID="txtFirstName" runat="server" ToolTip="<%# Container.CurrentPage.PageLink %>" />
other methods could be to have an Literal that is visible=false with the pagelink. Then find all Literals with the same method
or to change the id on the textbox to have the pageID
#47104
Jan 14, 2011 10:58
but you could also add it to your link button the same way you add the page link
<asp:LinkButton  runat="server" class="remove" Text="Poista" OnCommand="removeProduct" CommandArgument="<%# Container.CurrentPage.PageLink %>_<%#Container.FindControl("txtFirstName").UniqueID %>"></asp:LinkButton>
#47106
Edited, Jan 14, 2011 11:18
hey thanks for the reply
when I tried to add the pageID as a Id in the textbox. The textbox started dissappear from my page. I cant use tooltip because its showing up.Please suggest is there any other way to do so?
#47107
Edited, Jan 14, 2011 11:20
