Upload file to directory in code
I'm trying to upload a file in code to a directory in my File Manager called "Images" but I can't seem to get the directory name right. Any suggestions to what I'm doing wrong? This is what I've got so far but it doesn't seem to find or create a directory name "Images".
protected string UploadFile(Stream fileContent, string fileName)
    UnifiedDirectory dir;
    string virtualDir = "/Diverse/";
    if (HostingEnvironment.VirtualPathProvider.DirectoryExists(virtualDir))
        dir = VirtualPathHandler.Instance.GetDirectory(virtualDir, true) as UnifiedDirectory;
    else
        dir = UnifiedDirectory.CreateDirectory(virtualDir);
    if (dir != null)
        UnifiedFile uFile = dir.CreateFile(fileName);
        Stream s = uFile.Open(FileMode.CreateNew);
        byte[] buffer = new byte[fileContent.Length];
        int numBytesToRead = (int)fileContent.Length;
        fileContent.Read(buffer, 0, numBytesToRead);
        s.Write(buffer, 0, buffer.Length);
        s.Close();
        fileContent.Close();
        return uFile.VirtualPath;
    else return "";
#44029
Sep 29, 2010 13:56
Forgot to change the string virtualDir to ="/Images/". Doesn't make any difference since none of them work... :)
#44030
Sep 29, 2010 13:58
