Using a SAN for the VPP folders
Hi all
I have a SAN mapped on my web servers for the VPP folders to write to.  I can't get them working due to permission problems.
If I add the path top the VPP folders using the network path I get this error:
Access to the path '\\10.120.0.1\company$\VPP\PageFiles' is denied.
Exception Details: System.UnauthorizedAccessException: Access to the path '\\10.120.0.1\company$\VPP\PageFiles' is denied.
I have tried impersonating the ASP.NET identity for a user I have on the SAN but still no joy.
I can map a drive to the SAN on the web server using the user account I have to access the SAN and this works correclty but when I add the mapped drive path to the VPP folder I get this message:
Could not find a part of the path 'Z:\Company\VPP\PageFiles'.
I am fast running out of ideas.  Does anyone have any advice?
Cheers
#42592
Aug 26, 2010 16:56
longshot, but maybe you could try to add the computer-name to the vpp folder security: vpp-folder, properties, security, select object "computers" (default is off) and find your machine with the website, and add it to the list, like COMP123$. Note that this is just an idea :-)
And what happens if you add "Everyone" to the vpp, just as a test?
#42606
Aug 27, 2010 9:25
If it works with "Everyone" then I would do a installation with the Deployments center and add the path for the vpp. That way you will get the correct access rights set.
#42607
Aug 27, 2010 9:44
Hi guys
Thank you fro your suggestions, much appreciated.
The SAN has everyone permissions and I tried running the site through the deployment wizard.  It creates the VPP folders in the SAN which is a good sign.  When I start the site I get the following error when i use the Native path Provider:
The VirtualPathProvider configured to handle page files must return directories that implement IPageDirectory
Any ideas, I can't find anyone else who has had this error
Cheers, Paul
#42630
Aug 27, 2010 13:10
Hi all
In case anyone else has this problem it was the account I was running the application pool under.  I tried to impersonate the identity of the user in the web.config, to that of a user who has access, thinking that was adequate but it wasn't until I changed the account the app pool was running under that it worked correctly.
Cheers, Paul
#42761
Aug 31, 2010 15:40
