Live Monitor on CMS 6
Have now tried for a while to compile the CMS 6 sollution with the Live Monitor 2 dlls, with all but success. It seems like the EpiServer.Trace.CMS-DLL is build spesifically to use 6.0.494.0 version of the EpiServer-DLL. This is a bit of a problem when the released version of EpiServer CMS 6 has version 6.0.530.0.
Have anybody found a way to solve this problem?
Could not load file or assembly 'EPiServer, Version=6.0.494.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Regards,
Frode
#39928
Jun 07, 2010 16:43
Hi Frode!
Make sure that you have the correct runtime redirect for episerver.dll in web.config:
<runtime>
 <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <dependentAssembly>
        <assemblyIdentity name="EPiServer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
        <bindingRedirect oldVersion="5.2.375.0-6.65535.65535.65535" newVersion="6.0.530.0" />
      </dependentAssembly>
 </assemblyBinding>
</runtime>
/johan
#39929
Jun 07, 2010 17:28
Thank you very much Johan!
That saved my day/week. That explained why it worked on one server but not on the other. Visual Studio does not include this block when creating the project, however the CMS Site installer does.
For everybody else, the following block must be bresent in web.config:
      <dependentAssembly>
        <assemblyIdentity name="ElektroPost.Licensing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.BaseLibrary" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Blog" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Cms.Shell.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Configuration" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Data.Cache" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
        <bindingRedirect oldVersion="6.0.0.0-6.65535.65535.65535" newVersion="6.0.318.113" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Data" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Enterprise" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Events" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Framework" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.ImageLibrary" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Implementation" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Legacy4" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Licensing" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.LinkAnalyzer" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Log.Analyzers" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Log.Core" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Lucene" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Scheduler" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Scheduler.WKTL" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
        <bindingRedirect oldVersion="5.2.375.0-6.65535.65535.65535" newVersion="5.1.422.4" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Shell" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Shell.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.Web.WebControls" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.WebDav" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.WebParts" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.WorkflowFoundation" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.XForms" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="EPiServer.XmlRpc" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
      <dependentAssembly>
        <assemblyIdentity name="log4net" publicKeyToken="1b44e1d426115821" culture="neutral" />
        <bindingRedirect oldVersion="1.0.0.0-1.65535.65535.65535" newVersion="1.2.10.0" />
      <dependentAssembly>
        <assemblyIdentity name="Microsoft.Web.Services3" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <bindingRedirect oldVersion="3.0.0.0-3.65535.65535.65535" newVersion="3.0.0.0" />
      <dependentAssembly>
        <assemblyIdentity name="System.ComponentModel.Composition" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
        <bindingRedirect oldVersion="2009.0.0.0-2009.65535.65535.65535" newVersion="2009.22.10.0" />
      <dependentAssembly>
        <assemblyIdentity name="System.Web.DataVisualization" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <bindingRedirect oldVersion="3.0.0.0-3.65535.65535.65535" newVersion="3.5.0.0" />
      <dependentAssembly>
        <assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" culture="neutral" />
        <bindingRedirect oldVersion="1.0.0.0-1.65535.65535.65535" newVersion="1.0.0.0" />
    </assemblyBinding>
#39944
Jun 08, 2010 10:57
