set page name programmatically
i set the page name programmatically in the global.asax:
static void Instance_CreatingPage(object sender, EPiServer.PageEventArgs e)
e.Page.PageName ="xxx"
This works fine but i need to disable\hide the filed(property) name in edit mode to prevent the user to change the text.
I tried
static void Instance_LoadingPage(object sender, EPiServer.PageEventArgs e)
e.Page.Property["PageName"].DisplayEditUI = false;
but it doesn't work.
Suggestions?
#37928
Mar 24, 2010 10:27
I'm not completely sure that this is the problem, but in CMS5 PageData object properties are read-only, so that might be what is stopping you. You should try doing this:
PageData writablePage = e.Page.CreateWritableClone();
writablePage.Property["PageName"].DisplayEditUI = false;
I also can't see you saving the changes anywhere.
DataFactory.Instance.Save(writablePage, EPiServer.DataAccess.SaveAction.Publish);
I hope that helps!
#37935
Mar 24, 2010 11:37
Mar 24, 2010 11:51
I set the value with
and it works fine.
But i need to hide the property "page name" when the user edit the page.
#37939
Mar 24, 2010 11:53
Hi Ivan,
I think you could use Fredrik Haglunds code in this blog post: http://blog.fredrikhaglund.se/blog/2009/06/08/move-built-in-property-to-another-tab-when-editing/ , but instead set OwnerTab to "-1". I think that should work.
#37941
Mar 24, 2010 13:19
Another way is to subclass PropertyStringControl and use EPiServer.Core.PropertyControlClassFactory.Instance.RegisterClass from your global.asax Application_Start event handler to inject your subclass. In that class you can, for example, render the editcontrol (Textbox) read-only if the property name is PageName.
#37948
Mar 24, 2010 14:57
This is what we do to remove a property from edit mode:
Subscribe to to the LoadedPageEventHandler,
in it we do this: e.Page.Property.Remove("propname")
Regards,
Morten
#37951
Mar 24, 2010 15:38
Mar 25, 2010 7:55
i used
private void EditPanel_LoadedPage(EditPanel sender, LoadedPageEventArgs e)
e.Page.Property["PageName"].OwnerTab = anotherTabIndex;
In this way the user can't see the prorperty Name on the main Tab.
/Ivan
#37975
Mar 25, 2010 7:57
