I've never setup and run the migration script. But If I'm not rembering totally wrong I think a collegaue had a problem like this. I think the problem was that he by mistake hade setup the wrong tyype of Virtualpathprovider in the migrate to web.config.
i really need help on this. I migrate a site from iis 6 to iis7. all images (dynmaic files in the vpp folder) are missing.
This is my web.config, any suggestion. Thanks
<system.webServer>
<modules runAllManagedModulesForAllRequests="true">
<add name="InitializationModule" type="EPiServer.Web.InitializationModule, EPiServer" preCondition="managedHandler"/>
<add name="Initializer" type="EPiServer.Scheduler.Initializer, EPiServer.Scheduler" preCondition="managedHandler"/>
<add name="WorkflowRuntime" type="EPiServer.WorkflowFoundation.WorkflowSystem, EPiServer.WorkflowFoundation" preCondition="managedHandler"/>
<add name="UrlRewriteModule" type="EPiServer.Web.UrlRewriteModule, EPiServer" preCondition="managedHandler"/>
<add name="KeepIdForEPiTrace" type="EPiTrace.KeepIdForDataHandler,EPiTrace" preCondition="managedHandler"/>
<add name="Dropit.Extension" preCondition="managedHandler" type="Dropit.Extension.Handlers.HttpModule, Dropit.Extension"/>
<add name="ScriptModule" preCondition="managedHandler" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add name="EPiServerCommon" type="EPiServer.Common.Web.HttpModule, EPiServer.Common.Web" preCondition="managedHandler"/>
<add name="EPiServerMail" type="EPiServer.Mail.Core.Web.MailModule, EPiServer.Mail.Core.Web" preCondition="managedHandler"/>
<add name="ImageVault" type="ImageStoreNET.PluginStartup, ImageVault.EPiServer5"/>
<add name="IIS5XWildCardExtensionFix" type="ImageStoreNET.Classes.IIS5XWildCardExtensionFix, ImageStoreNET"/>
</modules>
<handlers>
<clear/>
<add name="Embed.aspx_*" path="Embed.aspx" verb="*" type="Se.MeridiumKalmar.Web.EmbeddedHandler, ImageVault.Core" preCondition="integratedMode,runtimeVersionv2.0"/>
<add name="ImageVaultHandler.aspx_*" path="ImageVaultHandler.aspx" verb="*" type="ImageStoreNET.Classes.Handlers.ImageHandler, ImageStoreNET" preCondition="integratedMode,runtimeVersionv2.0"/>
<remove name="WebServiceHandlerFactory-Integrated"/>
<remove name="ScriptHandlerFactory"/>
<remove name="ScriptHandlerFactoryAppServices"/>
<remove name="ScriptResource"/>
<add name="compcharts" verb="GET" path="cachedimageservice.axd" type="ComponentArt.Charting.CachedImageService,ComponentArt.Charting.WebChart" preCondition="integratedMode,runtimeVersionv2.0"/>
<add name="TraceHandler-Integrated" path="trace.axd" verb="GET,HEAD,POST,DEBUG" type="System.Web.Handlers.TraceHandler" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="WebAdminHandler-Integrated" path="WebAdmin.axd" verb="GET,DEBUG" type="System.Web.Handlers.WebAdminHandler" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="AssemblyResourceLoader-Integrated" path="WebResource.axd" verb="GET,DEBUG" type="System.Web.Handlers.AssemblyResourceLoader" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="PageHandlerFactory-Integrated" path="*.aspx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.PageHandlerFactory" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="SimpleHandlerFactory-Integrated" path="*.ashx" verb="GET,HEAD,POST,DEBUG" type="System.Web.UI.SimpleHandlerFactory" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="ScriptHandlerFactory" path="*.asmx" verb="*" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="HttpRemotingHandlerFactory-rem-Integrated" path="*.rem" verb="GET,HEAD,POST,DEBUG" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactory, System.Runtime.Remoting, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="HttpRemotingHandlerFactory-soap-Integrated" path="*.soap" verb="GET,HEAD,POST,DEBUG" type="System.Runtime.Remoting.Channels.Http.HttpRemotingHandlerFactory, System.Runtime.Remoting, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" modules="ManagedPipelineHandler" scriptProcessor="" resourceType="Unspecified" requireAccess="Script" allowPathInfo="false" preCondition="integratedMode" responseBufferLimit="4194304"/>
<add name="TRACEVerbHandler" path="*" verb="TRACE" type="" modules="ProtocolSupportModule" scriptProcessor="" resourceType="Unspecified" requireAccess="None" allowPathInfo="false" preCondition="" responseBufferLimit="4194304"/>
<add name="OPTIONSVerbHandler" path="*" verb="OPTIONS" type="" modules="ProtocolSupportModule" scriptProcessor="" resourceType="Unspecified" requireAccess="None" allowPathInfo="false" preCondition="" responseBufferLimit="4194304"/>
<add name="ComponentArtScriptHandler" verb="*" path="ComponentArtScript.axd" type="Dropit.ComponentArt.Web.UI.ScriptHandler,Dropit.ComponentArt.Web.UI" preCondition="integratedMode"/>
<add name="ScriptHandlerFactoryAppServices" verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" preCondition="integratedMode"/>
<add name="ScriptResource" verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" preCondition="integratedMode"/>
<add name="Telerik.Web.UI.WebResource" path="Telerik.Web.UI.WebResource.axd" verb="*" type="Telerik.Web.UI.WebResource, Telerik.Web.UI" />
<add name="StaticFileHandler" path="*" verb="*" modules="StaticFileModule,DefaultDocumentModule,DirectoryListingModule" resourceType="Either" requireAccess="Read"/>
</handlers>
<validation validateIntegratedModeConfiguration="false"/>
<httpErrors errorMode="Detailed" />
</system.webServer>
