Could not connect to net
2010-03-01 02:40:39,456 ERROR [1] EPiServer.Events.Remote.EventReplicationWCFProviders.RaiseEvent - Exception calling IEventReplication::RaiseEvent on remote object
System.ServiceModel.EndpointNotFoundException: Could not connect to net.tcp://IP address:13003/RemoteEventService. The connection attempt lasted for a time span of 00:00:10. TCP error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond IP address:13003.  ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond IPaddress:13003
   at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
   at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
   at System.ServiceModel.Channels.SocketConnectionInitiator.Connect(Uri uri, TimeSpan timeout)
Server stack trace:
   at System.ServiceModel.Channels.BufferedConnectionInitiator.Connect(Uri uri, TimeSpan timeout)
   at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
   at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
   at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
   at System.ServiceModel.Channels.ServiceChannel.EnsureOpened(TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs)
   at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   at EPiServer.Events.ServiceModel.IEventReplication.RaiseEvent(Guid raiserId, String siteId, Int32 sequenceNumber, Byte[] verificationData, Guid eventId, Object param)
   at EPiServer.Events.Proxies.EventReplicationProxy.RaiseEvent(Guid raiserId, String siteId, Int32 sequenceNumber, Byte[] verificationData, Guid eventId, Object param)
   at EPiServer.Events.Remote.EventReplicationWCFProviders.RaiseEvent(Guid raiserId, String siteId, Int32 sequenceNumber, Byte[] verificationData, Guid eventId, Object param)
#37295
Mar 02, 2010 7:04
