Using statistics log to get most popular pages - limited to 5?
I am using the statistics log to get the most hit pages, but I can only seem to get the five top pages. I use CMS 5 R2 SP2 and the code to get the dataset with the page id:s looks like this:
RealTimeAnalyzerView client = new RealTimeAnalyzerView();ITransformer transformer = (ITransformer)EPiServer.BaseLibrary.ClassFactory.CreateInstance(typeof(ITransformer), new object[0]);DataSet data = client.GetMaxHits(transformer.CreateURL(PageReference.StartPage))
#36771
Feb 10, 2010 13:58
Hi Magnus,
In EPiServer.LogService.exe.Config file, there is a key <EPnPublishedPagesMaxCount and default value is set to 5.
Try changing that value to whatever number you required
<EPnPublishedPagesMaxCount>5</EPnPublishedPagesMaxCount>
Doest it help?
#36773
Feb 10, 2010 14:24
No, changing that value does not change anything, it still only reports 5. I have changed the value, restarted the service and browsed many pages on the site.
#36804
Feb 11, 2010 7:51
You might get luckier with the setting "EPnMostVissitPagesMaxCount" instead.
And yes, it really spells Visit with 2 's' :-)
If left out, it will default to 5
/johan
#36808
Feb 11, 2010 10:02
Thanks Johan! I just found it using Reflector too, it was not in the example file.
#36810
Feb 11, 2010 10:39
Next issue: I'm trying to gather results from a subtree of the site (otherwise the start page will probably always be the top hit page), and I use ITransformer.CreateUrl to construct the argument for the GetMaxHits method from a PageReference. I get hits in all cases, but I get the same hits or at least I get the start page even though I'm searching nodes below the start page. Am I doing something wrong or can't this be done?
Edit:
I unleashed reflector on the class and it seems the statistics are only per-site... I suppose I should find another way to exclude some nodes from the statistics, I suppose I could selectively output the log generator in the pages for example?
#36811
Edited, Feb 11, 2010 11:09
