Object reference not set to an instance of an object
First i am making some changes to start page in episerver Edit.Then i am clicking save & view.After that if i try to publish the same page...i am getting the following error.And this error is coming in only IE.It's working fine in Mozilla.
And the problem is with only start page.We are using CMS5 version 5.2.375.236
Please find the error stack as below.
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
   EPiServer.Web.PropertyControls.PropertyDateControl.ApplyEditChanges() +12
   EPiServer.Web.PropertyControls.PropertyDataControl.ApplyChanges() +44
   EPiServer.PageBase.SetValuesForPropertyControls(Control control) +167
   EPiServer.PageBase.SetValuesForPropertyControls(Control control) +179
   EPiServer.PageBase.PrepareForSave() +90
   EPiServer.UI.Edit.EditPanel.SavePage() +76
   EPiServer.UI.Edit.EditPageButtonControl.Save(SaveAction saveAction, Boolean goToViewPage) +50
   EPiServer.UI.Edit.EditPageButtonControl.Publish_Click(Object sender, EventArgs e) +19
   EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +107
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +135
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
Thanks in advance
#46719
Dec 30, 2010 9:59
