are you using CMS6? In that case the path to the file is probably includes ui/CMS/Edit. Also, you should probably remove at least the VersionListControl.ascx part from the virtualPath of the actual provider (and correct it to ui/CMS/Edit)
Thank you for the answer!
I'm not using CMS6, you could see the core version the last post: "C:\Program Files (x86)\EPiServer\CMS\5.2.375.236\application\ui". There's no folder "CMS" under "UI" folder.
Ah, sorry, I didn't look at that post :) But have you tried removing the file name from the provider? Also, have you checked the order of the mapping VPP compared to the VPP containing the default files?
Yes, I tried different ways ...
I don't understand what did you mean. Could you explain this to me, please?
I need to make some changes to the VersionListControl.ascx. So, I faced with the same problem described in
http://world.episerver.com/Templates/Forum/Pages/thread.aspx?id=30740. However, all my actions have no effect - I still get the same core control. Here is the web.config part:
<add showInFileManager="false" virtualName ="Mapped Files" virtualPath="~/ui/edit/VersionListControl.ascx" name ="MappedFiles" type="EPiServer.Web.Hosting.VirtualPathMappedProvider,EPiServer"/>
<add name="UIFiles" virtualPath="~/UI/" physicalPath="C:\Program Files (x86)\EPiServer\CMS\5.2.375.236\application\ui" type="EPiServer.Web.Hosting.VirtualPathNonUnifiedProvider,EPiServer" />
<virtualPathMappings>
<add url="~/ui/edit/VersionListControl.ascx" mappedUrl="~/Templates/UICustomization/Edit/VersionListControl.ascx" />
</virtualPathMappings>
Could you tell me what am I doing wrong?
Thanks!
