Using asp:LoginStatus with LogoutPageUrl
Hi I am new to webdevelopment and i have just started to use episerver.
I was trying to use the Loginstatus LogoutPageUrl to redirect the user to another page after a logout. My problem is the LogoutPageUrl is working when set to a hard coded value but not when I am assigning using a method from the code behind.
Here is the code I am using:
   <LoggedInTemplate>
        <asp:LoginStatus ID="LoginStatus1" runat="server" LogoutText="LogoutTest" LogoutAction="Redirect" LogoutPageUrl="<%=GetLoginUrl() %>"/>
        <h1><%=GetLoginUrl() %></h1>
    </LoggedInTemplate>
<LoggedInTemplate>
<asp:LoginStatus ID="LoginStatus1" runat="server" LogoutText="LogoutTest" LogoutAction="Redirect" LogoutPageUrl="<%=GetLoginUrl() %>"/>  </LoggedInTemplate>
The GetLoginUrl is returning a string which is formated after.
GetLoginUrl:
  protected string GetLoginUrl()
            PageReference loginPageRef = CurrentPage["EPEHome"] as PageReference;
            if (loginPageRef != null)
                EPiServer.UrlBuilder url = new EPiServer.UrlBuilder(DataFactory.Instance.GetPage(loginPageRef).LinkURL);
                EPiServer.Global.UrlRewriteProvider.ConvertToExternal(url, null, System.Text.UTF8Encoding.UTF8);
                string friendlyUrl = UriSupport.AbsoluteUrlBySettings(url.ToString());
                return friendlyUrl;
            //LoginView.Visible = false;
            return string.Empty;
This will return a string like http://localhost:port/en/ for the start page. I am not sure why this is not working, when I replace the LogoutPageUrl="<%=GetLoginUrl() %>"/> in the .ascx with LogoutPageUrl="http://localhost:port/en/" everything works.
BR
Mattias
#46157
Nov 30, 2010 14:37
Hi, you can't use <%= when giving a value to a webcontrol. Use <%# and databind the control and it should work.
#46168
Nov 30, 2010 18:00
