EPi.CreateDialog returns object instead of value
In our custom property we use the FileManagerBrowser.aspx in a dialog to retreive the path to the selected image.
Here is the code:
function OpenFileDialogLink(url, pageId, parentPageId, folderId, selectedfile, tbClientID) {
    url += '?id=' + pageId + '&parent=' + parentPageId + '&folderid=' + folderId;
    url += '&browserselectionmode=image&selectedfile=' + selectedfile;
    var linkAttributes = new Object();
    var dialogArguments = linkAttributes;
    var features = { width: 600 };
    var callbackArguments = new Object();
    callbackArguments.myControlId = tbClientID;
    /* opens the filemanagerbrowser dialog */
    EPi.CreateDialog(url, OnDialogClosed, callbackArguments, dialogArguments, features);
    return false;
function OnDialogClosed(returnValue, callbackArguments) {
    if (returnValue != undefined && returnValue != 0) {
        var myCtrl = document.getElementById(callbackArguments.myControlId);
        myCtrl.value = returnValue;
        SetPreviewImage(callbackArguments.myControlId);
function OpenFileDialogLink(url, pageId, parentPageId, folderId, selectedfile, tbClientID) {    url += '?id=' + pageId + '&parent=' + parentPageId + '&folderid=' + folderId;    url += '&browserselectionmode=image&selectedfile=' + selectedfile;    var linkAttributes = new Object();    var dialogArguments = linkAttributes;    var features = { width: 600 };    var callbackArguments = new Object();    callbackArguments.myControlId = tbClientID;    /* opens the filemanagerbrowser dialog */    EPi.CreateDialog(url, OnDialogClosed, callbackArguments, dialogArguments, features);    return false;}
function OnDialogClosed(returnValue, callbackArguments) {    if (returnValue != undefined && returnValue != 0) {
        var myCtrl = document.getElementById(callbackArguments.myControlId);        myCtrl.value = returnValue;        SetPreviewImage(callbackArguments.myControlId);    }}
Calling it with the following code:
btFile.OnClientClick = string.Format("return OpenFileDialogLink('{0}', '{1}', '{2}', '{3}', '{4}', '{5}')",
                    EPiServer.UriSupport.ResolveUrlFromUIBySettings("edit/FileManagerBrowser.aspx"),
                    CurrentPage.PageLink, CurrentPage.ParentLink, pageDirName,
                    System.Web.HttpUtility.UrlEncode(tbFile.Text), tbFile.ClientID);
The problem is that the returnValue parameter is not the selected file's path but instead [object Object]. We are using EPiServer CMS 6. Any help would be very appreciated!
#45224
Nov 03, 2010 8:57
I should returned in a property on that object. I don't remember exaclty, but I would try returnValue.href. If that doesn't work I would add a breakpoint in FireBug and inspect the returnValue object more closely.
Regards
Per Gunsarfs
EPiServer Development Team
#45238
Nov 03, 2010 11:11
Hello Jonas,
Were you able to find a solution to the problem. Iam facing similar issues now. Since while trying to get the image url it returns an object, not sure why that is ??
Regards
MJ
#52602
Aug 04, 2011 15:44
I just had the exact same problem and used the developer tool in IE to find out what was going on.
Instead of this code:
function OnFileDialogClosed(returnValue, callbackArguments) {
I hade to use this to get hold of the value I wanted:
                myCtrl.value = returnValue.items[0].path
Don't really know the reason behind this though...
I should also add that this occurred after I upgraded a site from CMS5 R2 SP2 to CMS 6 R2.
Regards
Nicklas
#65416
Edited, Jan 29, 2013 14:26
