If by rendered in edit mode you mean that it is displayed in the editor when you come back at a later time to edit it again, I can't reproduce this behaviour. Editing dynamic properties of XHMTL string type works just as expected (using the new TinyMCE editor, haven't tried the old one).
Thats exactly what I mean. I'm also using TinyMCE. Everything works fine with "normal" pageproperties. And other types (not xhtml) works both with pageproperties and dynamic properties.
I have the same problem.
When inserting a >255 xhtml-string into dynamic properties it doesn't show the tinyMCE editor, just the regular textfield.
It works great on normal pages though.
Hello,
I have some dynamic properties in my EPiServer CMS 6 project. All dynamic properties works fine except those of type "xhtml-string (>255)". What happens is that the content of these properties aren't rendered in edit mode, but you can still add content, save and use it on pages. So its only a problem for editors. And, as I said, other dynamic properties works fine..
Any ideas?
