Nested Dynamic Content
Hello,
There are 2 dyanmiccontent (DC), one has 3-4 episerver properties and also there is one control thats been used, where as the other DC has only one field and no controls is associated with that so when render method is called we are just rendering a string from the session.
So in First DC in one property field i have dropped second DC, so whenever the page calls first DC it inturn calls the second DC, but when it doesn't render. It renders as plain text itself {DynamicContent:Description}
But if i drop second DC seperately then it is rendered properly. If i tie both it is not working. It's nothing but Nested DynamicContent
Please let me know if you guys were able to underestand
Rachappa
#44994
Oct 25, 2010 22:58
How do you render the XHtml property containing the Description dynamic content? It has to be rendered using the episerver property control, or perhaps not even that works inside other dynamic content.
The thing is, the Dynamic content is just that yellow span you see until it is picked up by some code inside the Property control which replaces it with the actual content. This has been discussed several times in the forum, here's one thread:
http://world.episerver.com/Templates/Forum/Pages/thread.aspx?id=26635
#44997
Oct 26, 2010 7:18
I can confirm that you can have nested dynamic content.
#44998
Oct 26, 2010 7:37
