Which EPiServer version? Are you running any plugins? Do you have any custom event handling for your file events?
We are using Episerver CMS5.Verion is 5.2.375.236.No plugins are runnig and no cutom event handling for file events.
Still i am having the problem while deleting the image from file manager.This error is not coming regularly.And even this error is coming in our production environment only.Can anbody has idea on lucene index service...restarting indexing service will make any sense..help me in this regard..thanks in advance
Getting System.IO.IOException: read past EOF while deleting image in file management.Please check the following Stack trace and advice how to overcome this.
[IOException: read past EOF]
Lucene.Net.Store.BufferedIndexInput.Refill() +233
Lucene.Net.Store.BufferedIndexInput.ReadByte() +21
Lucene.Net.Store.IndexInput.ReadInt() +13
Lucene.Net.Index.SegmentInfos.Read(Directory directory) +60
Lucene.Net.Index.AnonymousClassWith.DoBody() +45
Lucene.Net.Store.With.Run() +67
Lucene.Net.Index.IndexReader.Open(Directory directory, Boolean closeDirectory) +110
Lucene.Net.Index.IndexReader.Open(String path) +65
EPiServer.Web.Hosting.Versioning.Store.FileOperations.DeleteItemIdFromIndex(String filePath, Object fileId) +78
EPiServer.Web.Hosting.Versioning.Store.FileOperations.DeleteFile(Object dirId, Object fileId) +118
EPiServer.Web.Hosting.Versioning.VersioningFileHandler.Delete() +28
EPiServer.Web.Hosting.VersioningFile.Delete() +118
EPiServer.UI.Hosting.DeleteSelection.DeleteButton_Click(Object sender, EventArgs e) +327
EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +107
EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +135
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
EPiServer.UI.Admin.FileManagement.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +41
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +36
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
