You'd probably have to replace the standard aspx /ascx:es used by the edit interface. Start by finding the page or control which is holding the button / buttons you want to attach your event to. It's one of the files in the EPiServer install directory (usually placed in Program Files, check your virtual path mappings in web.config/episerver.config to see exactly where). Copy the file to your project.
Hopefully you can just add your javascript event to the button by adding some javascript code to your modified aspx/ascx. In some cases it might take manipulation of the codebehind. Use reflector to look at the class which the aspx/ascx inherits from. If you need to, you can get into the chain of inheritance by letting a class (codebehind) inherit from the class the original aspx/ascs inherits from, and let your new aspx/ascx inherit from this class.
Then look in episerver.config / web.config for the VirtualPathMappedProvider. That is included in the default config files but commented out. Activate it, and use the path mappings section to redirect the virtual path of the original aspx/ascx to your modified version.
You could write a EditPanelPlugIn that FindControl's the Save&Publish-button and injects the confirm()-script to it.
/johan
If you take a look at
http://www.slideshare.net/EPiServerMeetupOslo/episerver-behind-the-scene
page 25, there is a method here you could use
Hi Magnus, Johan and Anders.
Thank you very much for your help. I managed to get it working using the following code in an EditPanel Plugin:
EditPanel editPanel;
PropertyDataForm dataform;
public PlugInDescriptor[] List()
editPanel = HttpContext.Current.Handler as EditPanel;
if(editPanel != null)
editPanel.PreRender += new EventHandler(editPanel_PreRender);
return new PlugInDescriptor[] {};
public void editPanel_PreRender(object sender, Eventargs e)
dataForm = FindControl<PropertyDataForm>((Control)sender, null)
ToolButton SaveAndPublishButton = FindControl<ToolButton>(dataForm.Parent, "SaveAndPublish");
EPiServer.ClientScript.ScriptManager.Current.AddEventListener(SaveAndPublishButton, new ConfirmEvent(EventType.Click, "Are you sure you want to publish?"));
public T FinControl<T>(Control control, string id) where T : Control
T ctrl = control as T;
if(ctrl != null && (id == null || id.Equals(ctrl.ID)))
return ctrl;
foreach(Control c in control.Controls)
ctrl = FindControl<T>(c, id);
if(ctrl = null)
return ctrl.
return null;
Thank you guys once again.
I would like to add a javascript 'are you sure you want to publish' confirmation popup for every time someone wants to publish any page in edit mode. Any help on how to do this would be greatly appreciated it.
Thank you
