Exporting files problem (images/flash)
Dear All,
I am using Episerver 5.2 version. I have a bit complicated scenario, hoping someone helps.
I have a staging server and development server. Now On my staging server, client is constantly adding data, new files, delete files.
On the other hand, i am continuing my development on local server. At the end, when ihave to implement the changes, i normally create scripts for pagetemplates, and for new pages.
In this recent development, i have to upload say 100 files on my  local epi-server to use in a slideshow pro. Files are in diferent folders also. Problem i am facing, when i am trying to replica those folders and file on my staging site, I have to go and select file one by one through Export data utility - export files in episerver-admin. There are 100 files, and to select each file one by one is quite difficult. Can anyone suggest a better way of export physical files. (These are images, xml and flash files). I can not over write VPP folder as now client has modified VPP on staging area. Please if someone comments. Many thanks.
#36048
Jan 12, 2010 12:59
Enable WebDAV maybe ?
#36089
Edited, Jan 13, 2010 16:25
