Use swf file uploader in episerver
Hi guys
I have tried to implement a swf file uploader in episerver admin section..
http://www.codeproject.com/KB/aspnet/FlashUpload.aspx
This controls works perfectly on standard asp.net website. But when I try to use this control in episerver admin mode I got error "IO # 2038"  followed by "http error : 404".
I figure this could be caused by swf control can not find httphandler "upload.axd".
I put upload.cs on the root directory, so in a standard asp.net website, you can access it by going to mywebsite/upload.axd
But in episerver when I try to do that I got error 404.
in web.config I have this line
add verb="Post,Get" path="upload.axd" type="upload"
I am out of ideas, any help is appreciated.
#36059
Jan 13, 2010 6:24
Problem solved; on the asp.net page that uses the flashupload I changed the UploadPage to "/upload.ashx". Also I used the episerver sdk to upload file to episerver database.
 Check out my blog for this source code of this flash uploader
http://jefferychinet.blogspot.com/2010/01/episerver-flash-file-uploader.html
This flash file uploader allows users to select multiple file and upload them to a chosen episerver folder, it has a good upload progress bar and other features.
#36097
Jan 13, 2010 23:23
