PropertyCriteria on ParentLink not working?
                PageDataCollection oPages;
                PageReference oParent = PageReference.StartPage;
                //Filter on the right
                PropertyCriteriaCollection criterias = new PropertyCriteriaCollection();
                PropertyCriteria criteria = new PropertyCriteria();
                criteria.Type = PropertyDataType.Number;
                criteria.Name = "ParentLink";
                criteria.Condition = CompareCondition.Contained;
                criteria.Value = "27";
                criteria.Required = true;
                criterias.Add(criteria);
                oPages = DataFactory.Instance.FindPagesWithCriteria(PageReference.StartPage,criterias);
I try to retrieve the pages from my root with Criteria Filter (yes i know i can use the getchildren, but want also use another Criteria).
Can someone tell me what i am doing wrong?
#36214
Jan 19, 2010 14:49
All built in properties are prefixed with "Page". So try changing to:
criteria.Name = "PageParentLink";
Does that make any difference?
Regards
Per Gunsarfs
EPiServer development team
#36218
Jan 19, 2010 15:04
Hi Per, when i try that i get an error: "No compare condition is defined."
Any idea what can be wrong?
Ok, when i use this, i still got no results...
                criteria.Condition = CompareCondition.Equal;
                oPages = DataFactory.Instance.FindPagesWithCriteria(PageReference.StartPage, criterias);
                //Bind Datasource to Control
                MainNavRPT.DataSource = oPages;
                MainNavRPT.DataBind();
#36220
Edited, Jan 19, 2010 15:12
Ah, sorry CompareCondition.Contained should be: CompareCondition.Equal , changed that for debugging reasons ;)
#36221
Jan 19, 2010 15:15
Ok, had to change criteria type to PageReference, it's working now:
criteria.Type = PropertyDataType.PageReference;
#36222
Jan 19, 2010 15:24
