RootPath is probably just the path to the directory, for example "/Global/Documents" or whater paths you have in your file manager (in EPiServer). Programmtic access is found in the technote.
I need to list some files in a directory and I'm trying to do this by using <EPiServer:UnifiedFileTree>.
Following some examples, I find the following attribute: RootPath='<%#CurrentPage["WebBaseURL"]%>'.
But what is the property WebBaseURL? Because it is not possible to select a directory, using "URL to abc" type.
I've looked at http://world.episerver.com/Documentation/Items/Tech-Notes/EPiServer-CMS-4/EPiServer-462/Unified-File-System/, but I'm none the wiser.
Does anyone have an working example of how I can list files in a directory using Unified Files System?
