Hi Erik,
Did you solve this one? I'm also looking into the possibility of letting users of a trusted AD log in.
// Kind regards, Torbjörn
Could you not enable the global catalog on Sweden and then use this in your connection string ? Also for automatic login you will need to switch off Anonymous authentication via IIS
Hi: We would like to use the Windows Membership- & Role Providers to login users on an intranet. The users are stored in four different Active Directories (sweden, norway, denmark, finland). There is a trust between sweden and all the other countries, but the other countries doesn't have trust between eachother. The web server will be a part of the swedish domain.
Is it possible to use the above providers to enable automatic login for all users?
Thanks! Erik
