I just had the same problem, and found out that I needed to add MultiLanguage in the capabilities attribute in the pageProvider section in web.config. (I know this answer is a little late for you, but I'm posting this because somebody else might have the same problem... :-)
<pageProvider>
<providers>
<add name="XmlPageProvider" type="CodeSamples.XmlPageProvider, XmlPageProvider" entryPoint="3" capabilities="Create,Edit,Delete,Move,Copy,MultiLanguage" filePath="~\externalpages.xml"/>
</providers>
</pageProvider>
I am making a site which uses a Custom PageProvider to show a product database in episerver. The database is localized and now i'm having trouble getting which language the user is asking for.
In my GetLocalPage I get an ILanguageSelector which if I understand it correctly should use to find if its being requested a specific language.
In the XmlPageProvider example provided by EPiServer they say you should do something like this. (language is the ILanguageSelector)
