Converting database from Oracle to SQL server
Hello, has anyone successfully moved an EPiServer database (4.6x or 5.x) from Oracle to SQL Server? Did you use SQL Server Migration Assistant? Any other experience of this tool? I thought there was an EPiServer article about this (for 4.62), but I can't find it now.
#32076
Aug 21, 2009 11:17
  I suggest you use EPiServer export functionality on the Oracle site and import on the Sql Server site. Then you will miss:
  • 1) History of all pages
  • 2) A few things stored in Object store like data from EPiServer Statistics, WSRP and mirroring functionality.
  • 3) And probable some other small things
But I think that this is the easiest way to do a migration.
#32109
Aug 22, 2009 12:08
We have succesfully moved from Oracle to MS SQL with the use of a SSIS package.
This way we kept all PageIDs(not using FURL), mirroring info etc.
Our Oracle database was case sensitive and we did go with a case insesitive MS SQL implementation so we ended up with a little cleaning up, nothing major. Mostly in the tblSID table with users haveing registed them selves with ABBA@se.se and abba@se.se, as an example :-)
We had to translate the GUIDS from being stored as strings in Oracle to genuine GUIDS in MSSQL, and some other minor translations.
It went supprisingly smooth, all handled in a SSIS package, takes about 10min to pump data from Oracle to MS SQL with 40 000 pages + pageversions.
So it can be done :-)
Regards,
Morten
#33999
Oct 23, 2009 15:15
Get info, many thanks!
#34002
Oct 23, 2009 15:55
