virtualPathMappings and IIS 7
Hello,
I'm having problem with overriding the source for some aspx-pages in the edit-view using virtualPathMappings. When I test on my development machine using the build in Visual Studio Web Server everything works fine. However, when I switch over to run the application via IIS (and using the configuration file from our production environment) the virtualPathMappings are ignored.
I'm running IIS in Integrated Pipeline mode (Vista on my local machine and Win 2008 at the server) and guessing that's some http-module that isn't loaded correct in the IIS 7 configuration file or something like that. Anyone with a clue what may is causing this problem?
Regards,
Karl
#31257
Jul 14, 2009 15:07
