Get values from custom property inheriting PropertyMultipleValue
Hi folks
* Using CMS5 R2
I've created a custom property that inherits from PropertyMultipleValue on the assumption that I can store multiple values in a comma delimited string.  Using the SetDefaultValue method, I set the initial value to "0,0" like so:
Protected Overrides Sub SetDefaultValue()  Me.String = "value1,value2" End Sub
My assumption was that I should have been able to retrieve the values like so:
PropertyName.Value(0) and PropertyName.Value(1)
However, the above will merely return an index within the string.  How do I retrieve the values from the string?  Do I need to split the string?  And if so, how is the PropertyMultipleValue different from PropertyString?
#31210
Jul 09, 2009 6:29
