You can use VirtualPathMappings to handle that. The web.config would be settings will be similar to this:
I need to make a small change to the AdminGroup.aspx file, but don't want to make it in the C:\Program Files\EPiServer\CMS\5.2.375.7\Application\UI\Admin\AdminGroup.aspx as it is shared by other EPiServer sites.
EPi4 used shadow folders to accomplish that.
Danie
