Configuration problem with sites
 I have got the following problem with the web.config file. For some reason ÉPiServer thinks that I have got multiple sites, so it tells me to give the site a unique ID so I do, then it forces me to add sitehosts node I do but then it tells me that I need a enterprise license. So the question is how can I tell EPi that this is the only site there is, or is there another way to get around the problem, I have given a section of the web.config file and the error message given when I have done a change to it.
I have got a developer license. F
<sites>
      <site siteId="unknown" description="Test site">
        <siteSettings categoryId="1" ... />
      </site>
    </sites>
Two or more sites have the same siteId 'unknown' in <site>. The siteId must be unique for each site
<sites>
      <site siteId="unknown1" description="Test site">
      </site>
    </sites>
Only one <site> section without a <siteHosts> element is allowed. A <siteHosts> <add name="*" /> </siteHosts> is the same as not defining a siteHosts element.
<sites>
        <siteHosts>
          <add name="http://localhost:6666/Testing/" />
        </siteHosts>
        <siteSettings categoryId="1" .../>
      </site>
    </sites>
web.config contains more than one <settings> section. This requires an Enterprise license.
#29892
May 20, 2009 12:51
