BuildQueryString with FriendlyUrls (CMS 5)
I'm having a bit of a problem regarding the UriSupport.BuildQueryString method.  I have this link to which I want to add three parameters. I do the following:
NameValueCollection myCol = new NameValueCollection();
            myCol.Add("Comment", "false");
            myCol.Add("EditMode", "true");
string redirect = CurrentPage.LinkURL + UriSupport.BuildQueryString(myCol);
When I click my link the page can't be displayed. I've altered the code above several times but with no luck. Does anybody have any solutions to my problem?
#29847
May 19, 2009 9:56
I've used the BuildQueryString method without any problems.
What is the value of your redirect string?
#29848
May 19, 2009 10:32
Ok, dp you have any sample code I can look at?
My redirect string from the code above looks like this:
"/templates/pages/MyPage.aspx?id=516&epslanguage=svComment=false&EditMode=true"
As you can see it's wrong :-)
#29849
May 19, 2009 10:44
I would use an UrlBuilder instead.
UrlBuilder ub = new UrlBuilder(CurrentPage.LinkURL);
ub.QueryCollection.Add("parameter1", "value1");
ub.QueryCollection.Add("parameter2", "value2");
Response.Redirect(ub.ToString(), true);
 The problem with your approach is that you append the correctly built "BuildQueryString", but you miss the "&"/"?" between the strings when you just concat them.
#29852
May 19, 2009 11:05
Tack! Funkar perfekt!
#29867
May 19, 2009 15:33
