Enterprise Configuration Issues in authentication
Hi all,
Just read an SDK article about Membership and Role providers. Last chapter is about Enterprise issues, http://sdk.episerver.com/library/CMS5/Developers%20Guide/Membership%20and%20Role%20Providers.htm?id=24871
"If you are using the SQl Server membership/role provider and want to use the same set of users / roles for all sites using the same web.config files (probably the most common scenario), you need to use a separate database for the user/role information."
I understood this scenario is about having one CMS 5 R2 installed and multiple sites set up in IIS and also configured in the web.config. Could someone clarify why and when is this separate database needed ? I might understand this if there was multiple installations and web.configs and then both sites needs to point to the same database... what did I miss here :-)
Thanks in advance !
/Esa
#29120
Apr 07, 2009 15:03
Hi Esa,
You're right. There is no need for a seperate database for the sql member and role provider. You can place these tables in the episerver db as usual. We will update the documentation accordingly.
#29789
May 14, 2009 10:44
