Donut caching and output cache in R2
Hi all,
I am developing a site that uses output caching through EPiServer. I need a part of a page (an Extension function) to be excluded from the output cached since it contains a Captcha image. Is there any way to exclude this user control from the output cache?
 I have tried  the PartialCaching(0) attribute for the Extension function user control, but Extension doesn´t allow this attribute. What to do?
Regards,
Tobias
#28823
Mar 23, 2009 17:17
Quess you need to do your own area caching. EPiServer do all or nothing as far as I know. have some area cache code you can try. send me a mail if you want it
#28845
Mar 25, 2009 0:39
Have look at the asp:Substitution control, it gives you the ability to insert a string into a cached page. I use it on an EPiServer site with caching.
In your case you could insert the url to the Captacha image, or image handler.
//Morten
#28848
Mar 25, 2009 7:55
Cool, have to try that out
#28849
Mar 25, 2009 8:00
Did any of you get the donut caching working successfully?  If so, can you provide some additional details on your approach?  Thanks!
#56228
Jan 12, 2012 16:58
