Hi, I guess you already find out how. But for all others thats searches the forum the solution can be nice.
You can add a <asp:ValidationSummary > control and connect your xForm with the property ValidationGroup.
<asp:ValidationSummary ID="XFormValidationSummary" runat="server" ValidationGroup="XForm" />
<xforms:xformcontrol runat="server" ID="FormControl" ValidationGroup="XForm" />
There is also some Global.asax hack (or code in the code behind of the xForm usercontrol) to use to extend the behavior for the xForm validation. Check the PublicTemplate package!
Hi Henrik,
u r using the tag <xforms:xformcontrol> it means u r not creating an xform in ADMIN mode in EPIServer?
Hi all,
I'm using xforms within a site but, when a field fails validation, I'd like to show a descriptive message before the field rather than an asterisk after the field. Is there an easy way to do this?
