XHTML 1.0 Strict
I want to have my EPiServer site comply with the XHTML 1.0 Strict standard but EPiServer produces some JavaScript which is invalid. According to an XHTML validator (http://validator.w3.org/check) the following JavaScript line (produced by EPiServer) does not comply with the standard:
menu1.AddMenuItem('Hurtigrediger',null,'window.open(\'http://localhost/mysite/UI/edit/Default.aspx?id=3&epslanguage=da&mode=simpleeditmode\',\'_self\')','true','/mysite/App_Themes/Default/Images/Tools/QuickEdit.gif',null);
The JavaScript block generated by EPiServer is parsed by the validator because it is not marked as 'CDATA' (see http://javascript.about.com/library/blxhtml.htm), and so the use of ampersands is wrong - they should have been replaced by '&' according to the standard.
So is there some way that I can either make EPiServer replace the ampersands, or make EPiServer mark the javascript as 'CDATA'?
#27951
Feb 14, 2009 12:15
Hi Søren!
Try to validate the page as a visitor (not logged in) to get a realistic result with less interferance from EPiServer's On Page Edit feature.
Also try to inherit from SimplePage instead of TemplatePage to turn off some EPiServer features.
#27961
Feb 15, 2009 14:48
Another thing to do in web.config under the <system.web> section:
<xhtmlConformance mode="Strict" />
One of the things that this declaration do is make the form tag validate correctly.
/Hans
#27969
Edited, Feb 16, 2009 11:47
